But I think we need to take working motorbikes
West to East run ..
- katmarch
- Committee Member
- Has thanked: 9 times
- Been thanked: 115 times
Re: West to East run ..
Apparently not https://www.yha.org.uk/stay/whats-it-li ... ommodation
- Katfish
- Been thanked: 29 times
- Katfish
- Has thanked: 119 times
- Been thanked: 257 times
Jonty and I are expecting to be there mid afternoon.
Should be leaving Iron bridge at 09.00 for a run up to the Horseshoe Pass and then down past Lake Bala.
Unless the forecast changes for the worse then it’ll be down trough Welshpool.
- Been thanked: 715 times
Booking in time is after 2pm at Cardigan castle.
The YHA sites state that you can hire towels or bring your own.
As for weather....change the site you check on...some same fine others showery others a mix. Eitherway it'll be warm.
tune in tomorrow as I will post info about getting into rooms at cardigan castle ..You will need pin codes etc .. oooh very exciting!
Smand and I will be leaving our gaff 1100 ish ...4hrs or so for us .. M6/56..A483 in to Welshpool ( about 1/2 way ) 1 ish.
katana11023
- Has thanked: 1 time
- Been thanked: 5 times
