Pop Carb removal
payton6uk
Has thanked: 1 time
Pop Carb removal
Post by payton6uk » Sat Apr 21, 2018 6:58 pm
my bike worked fine but it ran rough on idle, I took the carbs out and gave them a quick clean it worked great but it then had a hole in the fuel pipe... so I needed to take the carbs out again, after I put them back in again 2 cylinders aren't firing... before I remove the carbs again is there a better way to remove the carbs? I'm currently removing battery/battery tray/air filter/undo clamps.... man handle carbs out :D
Its just I'm worried I'm damaging something.
Thanks for any help you can give
Re: Pop Carb removal
Post by PaulD » Sat Apr 21, 2018 7:09 pm
I think all the Kats are the same, I know my 1100 is! The only tip I can give is to use a heat gun of some sort to soften the inlet and air box rubbers which helps a lot. I noticed on mine the inlet rubbers where marked L & R and they did seem to go back easier when they where put in the correct side?
pop-up
Has thanked: 10 times
Been thanked: 57 times
Post by pop-up » Sat Apr 21, 2018 7:30 pm
Before you pull them out again, which I agree is a pain in the arsenal, have a look at the wiring for the coils. You might find that during the removal struggle one of the blades has come away/broken.
payton6uk
Has thanked: 1 time
Post by payton6uk » Sat Apr 21, 2018 7:49 pm
I'll take a look but the problem is its 1+2 that's not working
Been thanked: 721 times
Post by fossie » Sat Apr 21, 2018 11:34 pm
I would personally spray we 40 on the choke slide bar and work it until it slides easily. Sometimes the cable operation stops the return completely of this bar so some choke is on and some not.
As for refitting carbs , yep hairdryer on the rubbers, fit to the airbox first , tighten the clamps ...but not very tight. Then with soften inlet rubbers push the airbox forward , it will resist a it then plop on.
Katfish
Been thanked: 30 times
Post by Katfish » Wed Apr 25, 2018 5:13 pm
Or be like me and don’t have the air box, makes life so much easier and running so much worse :lol:
Andy...KOC 298
Snap, Crackle & Pop Up
payton6uk
Has thanked: 1 time
Post by payton6uk » Fri Apr 27, 2018 8:02 pm
Tempting Katfish but I'll try again :D this time with the hairdryer... I'm sure my wife won't mind me borrowing hers :lol:
Post by PaulD » Sat Apr 28, 2018 6:46 am
payton6uk wrote:Tempting Katfish but I'll try again :D this time with the hairdryer... I'm sure my wife won't mind me borrowing hers :lol:
What :shock: you mean to say you don’t have your own hairdryer? shame on you sir. Imagine the disgrace of waving a PINK hairdryer around in yer man cave :lol:
Personally I use a B&D paint stripper gun, loadsa uses including warming up crankcases to fit bearings etc
Post by fossie » Sat Apr 28, 2018 1:43 pm
Paul Kats being 4 stroke don't require frequent crankcase bearing interaction. What you going to do in the spare time? :lol:
Post by PaulD » Sat Apr 28, 2018 8:02 pm
fossie wrote:Paul Kats being 4 stroke don't require frequent crankcase bearing interaction. What you going to do in the spare time? :lol:
Ah right, maybe I should have a boot sale with all my EX 2T stuff?
Thought, do two strokes have boots?
