Pop Carb removal
pop-up
Has thanked: 10 times
Been thanked: 57 times
Re: Pop Carb removal
Post by pop-up » Tue May 01, 2018 6:46 pm
Getting back to topic, has the problem been found /sorted?
fetishkat
Has thanked: 254 times
Been thanked: 17 times
Post by fetishkat » Tue May 01, 2018 7:55 pm
Just a thought, dangerous I know!!!! Have you checked the coils and their connections?
payton6uk
Has thanked: 1 time
Post by payton6uk » Thu May 03, 2018 8:44 pm
So I took the carbs back off again... quick clean... back in all 4 cylinders firing again :D
But I've still got to solve the original issue.... erratic idle.... something tells be the carbs are coming off again :cry:
Been thanked: 721 times
Post by fossie » Thu May 03, 2018 9:43 pm
How erratic ? If you turn the tick over up to say 1500 rpm. Does it smooth out? If so it is balancing.
Also as said check and clean coil connections. May seem obvious. But renew the plugs or clean them and refit in different cyls to see if the issue moves.
payton6uk
Has thanked: 1 time
Post by payton6uk » Sun May 06, 2018 6:27 pm
if I have it around 1000-1500 it will stall.. so stable around 2000+ I'll take a look at the coils, the plugs are less than a year old with only about 500miles on them. but I might replace anyway.... if not I'll look at getting the carbs balance. Thanks
Post by fossie » Sat Jul 07, 2018 12:19 am
We assume that because the machine is now on eBay etc that ...the balancing sorted the issue ;)
