- Has thanked: 637 times
- Been thanked: 242 times
Post
by Uncle Bob » Tue Apr 26, 2022 8:35 pm
pookie wrote: ↑Tue Apr 26, 2022 7:00 pm
Try out this Japanese website for help, I've found it invaluble for my 250 Kat, if it's in Japanese then Google translate will be needed, there's a whole section on troublshooting the cdi unit, click on 'igniter'
http://www1.synapse.ne.jp/s-hara/bandit/index.html
I do like the Japanese to English translate on Chrome, from that page I can learn..
Do fans really turn around?
Is it possible to improve the weakness of low rotation?
Bill:
I do have a CDI somewhere I'm sure. I could send, though it'd have to be by a postal service that gave a good insurance! It will take me a while to find it in the garage though it you did want to try...
You can get the Chinese clone ones which people have used before (and yours looks like it might be?)
https://www.aliexpress.com/item/32449849810.html
William.sn032
- Has thanked: 4 times
- Been thanked: 1 time
Post
by William.sn032 » Sun May 01, 2022 3:24 am
Thanks very much for the offer uncle Bob ,but I've ordered the Chinese cdi along with another new battery ,as I'm less than impressed with its performance....so let's hope this solves the problem...I'll keep you posted....
Post
by Smallkat » Sat May 07, 2022 2:38 pm
Hi William,
A belated welcome to hell from a fellow 400 sufferer. Mine currently has no sparks!
Regards,
Dean
- Been thanked: 714 times
Post
by fossie » Sun May 08, 2022 7:18 pm
Smallkat wrote: ↑Sat May 07, 2022 2:38 pm
Hi William,
Regards,
Dean
If no sparks at all , check side stand switch and if yours has the clutch lever cut out join the wires and get rid . Also obviously kill switch ....just join the wires and get rid.
Post
by Smallkat » Mon May 09, 2022 1:23 pm
I got a new sidestand switch off ebay, so I am going to swap that out. That is when I can bring myself to look at it.
Mine doesn't have a clutch switch.
Checked the kill switch and readings are correct.
Thanks for the further suggestions. Everything helps.
William.sn032
Post
by William.sn032 » Sun May 22, 2022 7:05 am
Hi Dean,
Thanks for reaching out....boy its been a struggle,but finally got the Katana running (all be it roughly)..but it's a start!
Post
by fossie » Sun May 22, 2022 8:52 am
And the secret to your partial success ?
It is repeatable .
William.sn032
Post
by William.sn032 » Sun May 22, 2022 6:17 pm
Hi Fossie
The new battery I bought wasn't holding its charge..... so i purchased another , changed the coils, leads, cleaned the new plugs again disconnected the lights .....some assistance with a can of easy start after removing the airbox then eventually it fired up ....Happy days ..such a shame because I purchased an extra box of matches, as I getting to the point of no return!!......lol
William.sn032
Post
by William.sn032 » Sun May 22, 2022 6:21 pm
Does anybody know if any of the other katanas choke cable are compatible with the 400.....thanks in advance.....
Post
by Smallkat » Wed May 25, 2022 11:12 am
The 250 and 400 have the same (discontinued) part number 58410-45D00. Bigger Kats have a different part number, as I would think they are longer.
I might have my old cable somewhere, if you want to get it copied at Venhill or similar.
