250 igniter
Posted: Wed Oct 26, 2022 12:01 pm
by Tonykat
Hi, more problems with my 250, fault traced to the igniter, I have replaced the igniter with the one off my 400 and engine runs but will this cause problems? Is there difference with rev limiter? The 400 one came from aliexpress will have to search for a 250 one.
Re: 250 igniter
Posted: Wed Oct 26, 2022 12:25 pm
by Tonykat
Found this one on Aliexpress
Re: 250 igniter
Posted: Wed Oct 26, 2022 4:57 pm
by Smallkat
That's the same brand one I have on my 400, which works fine. The 400 Igniter does have a 10,500rpm limiter. I don't know if the igniter controls the ignition advance though. You would imagine that there would be differences between the 250 and 400.
Smallkat even started first time after a few days layoff today!
Re: 250 igniter
Posted: Wed Oct 26, 2022 5:50 pm
by Tonykat
Hi, I have the same make on my 400 as well, but have not been on the road since fitting. Ordered the 250 one and cross fingers it will cure my problems.
Re: 250 igniter
Posted: Wed Oct 26, 2022 6:47 pm
Using a 400 one on a 250 and visa versa won't cause any problems other than if you use the 250 on a 400!the redline is well past the rocker cover
The other way round just means top gear is pretty void
Re: 250 igniter
Posted: Wed Oct 26, 2022 9:50 pm
by Tonykat
Thank you Fossie
