Side Stand: Will Not Stay Down / Flicks Up
Posted: Sun Apr 26, 2020 7:43 am
by jeznewsome
I have had somewhat of a problem with the sidestand since I got the bike with the side stand not staying down (about 50%) of the time. This has lead to me nearly dropping the bike a couple of times....not good!
So I took it apart and nothing seems excessively worn or out of place. On reassembly with a little grease it is now a consistent (100%) problem!
A little video
MOV_2234 by
jeznewsome, on Flickr
I have tried the spring in a number of orientations with no change in behaviour.
I assume that there is something wrong with the geometry of the stand? It is that the 'stop' is not at the right angle i.e. the stand doesn't rotate far enough forward to go 'over centre'
Anyone able to provide a photo of a working stand to show the angles etc? I'd like a little guidance before I start attacking the area with a file
TIA
Re: Side Stand: Will Not Stay Down / Flicks Up
Posted: Sun Apr 26, 2020 8:39 am
It's a German import isn't it?
Then stop trying to stop it!
It won't ....its part of the German TUV test, the stand MUST flip up when wieght us removed to remove the chance of you riding away with it down and having an accident!! A simple warning light, a nodduuale of rubber on the stand as per most place would've surficed....
2 of mine are like it , a weaker Spring helps but can leave the stand floppy I don't mind ....but I suspect you will. You get a sticker made up in the form of the official looking decal. "Danger suicide stand fitted."
Personally I just adapt my dismount method to keep the left leg forward behind the stand until the bike is on it.
In the 90's many Ducati's ended up on their side due to this legislation and they tried making 1 EU model to save costs ...but make a fortune in replacement indicator/ panels
Posted: Sun Apr 26, 2020 8:54 am
by Pedda
You could relocate the pin. I did that on a Kat which had it like non German frames.
Posted: Sun Apr 26, 2020 9:35 am
by pop-up
Posted: Mon Apr 27, 2020 5:55 am
by jeznewsome
Fossie, pedda, thanks for the input. It's a pain and I would like to change it if possible.
Anyone got or could take a photo of the pin location on an non German bike.
Posted: Mon Apr 27, 2020 6:05 am
by jeznewsome
.....no worries, once you see it, it's obvious!
Posted: Mon Apr 27, 2020 8:28 am
by Pedda
jeznewsome wrote: ↑Mon Apr 27, 2020 5:55 am
Have a look into my thread 'Everlasting race kat project'. On page 7 you'll find what you are looking for.
Posted: Tue Apr 28, 2020 11:47 am
by jeznewsome
Yup useful piccie there, I now need to talk nicely, at a safe distance, to my neighbour as he is a welder!
Posted: Tue May 05, 2020 7:05 pm
by jeznewsome
Still need to talk to the welder but now ready, after half an hour in the garage with an 8mm bolt, a drill, an angle grinder and a couple of files
2020-05-05_07-55-04 by
