Spark plugs
Posted: Wed Mar 03, 2021 8:37 pm
by Moggie47
Hi, need to change plugs on my 82 gsx750 katana sz, took out NGK D7ea,s and have NGK D 8ea,s to go
Back in. Which are the correct plugs as I have online information saying both are correct? Thanks.
Re: Spark plugs
Posted: Wed Mar 03, 2021 10:22 pm
by Kryten
Had a look at my Suzuki manual.
Either NGK D8EA for E-01, 24, 25, 30, 34
Or DR8ES for the others!
So if you have a Germany, Ireland, Croatia, Dunno, Bulgaria market bike then the book says D8EA.
But to be honest it probably wont make enough difference to worry about.
I would bung in the ‘8 as it’s the stated heat range.
Re: Spark plugs
Posted: Wed Mar 03, 2021 10:42 pm
I don't know why it's got 7's in ...has it been rejetted....for somewhere other than our climate?
Re: Spark plugs
Posted: Wed Mar 03, 2021 11:03 pm
by Kryten
fossie wrote: ↑Wed Mar 03, 2021 10:42 pm
After I posted that, I looked at the NGK place.
They suggest ‘7 heat range. Just to confoose uz
But I’d still throw some ‘8s at it. Just like Skruffy Kat is running.
Re: Spark plugs
Posted: Thu Mar 04, 2021 1:21 am
The NGK catalogue on line isn't usually UK , It's Yank ( spelling Timothy) .
Used to get issues when I worked in parts dept with people looking on line then ordering ....then complain about poor running , like it was our fault.
Personally I have always used DR8 ES L as it is a superceed to EA and easier to come by.
Re: Spark plugs
Posted: Thu Mar 04, 2021 2:04 pm
by Moggie47
Thanks, I will put the “8,s in “. Bikes running standard air box etc so not known why it had D7ea in.
Ps was Italian import.
Re: Spark plugs
Posted: Mon Mar 08, 2021 11:11 am
by katmarch
I run the DR8EIX
Re: Spark plugs
Posted: Tue Mar 16, 2021 11:15 am
by sparki
Moggie47 wrote: ↑Thu Mar 04, 2021 2:04 pm
was Italian import.
so engine number starts with R701 then? if it does its a nicer 750 than a GS75, better cams in it
Re: Spark plugs
Posted: Wed Mar 17, 2021 2:22 pm
by Moggie47
Hi, yes the engine number is R701, and it’s running well with the d8eas in.
