Pop up tail piece fitted
- Has thanked: 5 times
- Been thanked: 21 times
Thanks to the help of members I’ve got the electrics working and the back end complete. The license place holder I’ve got ain’t the right one so had to make do and fabricate parts to fit the tail piece. Not pukka but it’ll do me for now. Now onto the carb cleaning.
- Has thanked: 139 times
- Been thanked: 685 times
Re: Pop up tail piece fitted
The bit you are missing is the bottom of the mudguard it has been cut off , the number plate bracket bolts to that .
When refitting the carbs , heat up the inlets with a hairdryer fit the to the airbox first then lever the airbox forward until a plop indicates they are seated in inlets .
You have fitted the airbox already haven't you ?
