Kat clocks
busatoon99
Re: Kat clocks
Post by busatoon99 » Fri Nov 29, 2013 9:00 pm
fossie wrote:The sender from an Es tank would obviously fit, so would the GSX 400 f.
Would carpentry tools suffice in cutting a location for it?
Well i would not be using a hand saw or a 50mm bevel edged chisel, tho nailing it in to place with my paslode framing nail gun would be very quick but not exactly leek free :shock: :D
Depending on the size and shape i would either use a metal hole cutter or just chain drill it and file to shape.
Getting hold of a katana fuel gague or set of clocks will be the tricky bit, unless you can point me in the right direction ;)
Been thanked: 716 times
Re: Kat clocks
Post by fossie » Fri Nov 29, 2013 9:03 pm
The direction you'd need to look is South east ..............Australia or better New Zealand, there is a kiwi who breaks SE /SF.
busatoon99
Re: Kat clocks
Post by busatoon99 » Fri Nov 29, 2013 9:15 pm
Convict or kiwi land :shock: :shock:
If you have a web address for them an enquiry would not do any harm.
Re: Kat clocks
Post by fossie » Sat Nov 30, 2013 9:13 pm
bmccarthy@xtra.co.nz is the contact we had for him. You need GSX750 SF/SG clocks.
busatoon99
Re: Kat clocks
Post by busatoon99 » Sat Nov 30, 2013 9:22 pm
Nice one fossie, i will get a email off to them.
Cheers :)
busatoon99
Re: Kat clocks
Post by busatoon99 » Sun Dec 01, 2013 9:27 am
fossie wrote:bmccarthy@xtra.co.nz is the contact we had for him. You need GSX750 SF/SG clocks.
I sent an email off to them and got a very fast reply. Sadly they dont have any in stock. Ive sent emails to 3 other "bike wreckers" in nz so its wait and see time.
