Tech head needed
Posted: Mon Oct 10, 2011 7:25 pm
by Katman
As I'm recovering from a bad back (fugging GT), I'm spending a lot of time on the floor so thought I'd try to sort out my vid collection...well there about the same level, shame TV's so damn high tho cos I'm gonna end up with crick in neck soon.
I've just found a tape of 1992 round of BSB from Brands, with the likes of McElnea on the Loctite YZF, Reynolds on the Kwak, R Dunlop on JPS Norton....bliss
So what do I need to transfer this from tape to PC & is there prog I can clean recording up with?
Re: Tech head needed
Posted: Mon Oct 10, 2011 9:44 pm
by Cat
Google it??
Posted: Mon Oct 10, 2011 9:54 pm
by Pedda
Cat wrote:Google it??
Nah, I'm sure that won't transfer it...
Posted: Mon Oct 10, 2011 10:03 pm
by Cat
Hahaha. Well I was just thinking that jez probably doesn't even realise the internet is for stuff other than porn anyway really..yes jez I mean kats honest
Posted: Tue Oct 11, 2011 6:18 am
Prob loads of ways of doing it. but easiest would be to use a combined vcr and dvd writer machine.maybe someone you know has one.
or try:
http://www.ebay.co.uk/itm/USB-Video-Gra ... 353wt_1026" onclick="window.open(this.href);return false;
Posted: Tue Oct 11, 2011 7:51 am
by Kryten
There's a software company called Roxio that does all the conversion software. I think that you can get the leads as well to convert from SCART to component video as well.
Posted: Tue Oct 11, 2011 5:12 pm
by Katgeezer
The dvd/vcr combi is the easiest way but of course you'll only get vcr quality picture on the dvd.
To do a direct transfer you'd probably need a TV card (so you could tune to the tv channel) or an S-video card to plug your vcr into.
There are quite a few shops that'll do it for you at a not toooo silly price and they'll probably run it thro' an enhancement program if you ask but there's not a massive amount you can do to clean it up.
Hope this helps Jez.
Posted: Thu Oct 20, 2011 6:35 pm
by Russbusa
Play it through a sony digital8 camcorder thats been reprogrammed to have the outputs used as inputs (dv in) either save it to the tape which will give you digital output OR use it as a pass through and record straight to hard disk
simples
Posted: Fri Oct 21, 2011 12:38 pm
by Katman
Russbusa wrote:Play it through a sony digital8 camcorder thats been reprogrammed to have the outputs used as inputs (dv in) either save it to the tape which will give you digital output OR use it as a pass through and record straight to hard disk
simples
Simples IF you HAVE a digital8 camcorder.....for the rest of us, not so simples
Posted: Sat Oct 22, 2011 8:23 am
by Russbusa
Send it to me and i'll do it for you and will put it onto a dvd as an avi file (huge) you can edit it, play it on a pc or it will play in most dvd players too
