Avon Roadriders
Posted: Wed Dec 28, 2011 6:46 pm
by 1888
Do you have them on your bike? Look at mine after 1000 miles :o
Look at the centre groove
http://i812.photobucket.com/albums/zz43 ... /Tyre1.jpg" onclick="window.open(this.href);return false;
I got a refund from Avon no problem and the seller told me this is not uncommon for the roadrider brand. It seem to only be with larger bikes. People i have spoken to on other forums have also had this problem and one person says he just uses them as the split is not going right through. Dont think i would like that idea.
Keep an eye on your rear tyre peeps.
Re: Avon Roadriders
Posted: Wed Dec 28, 2011 6:57 pm
by Cold Snail
I've got one on the back of the 650.
I'll have a look at the weekend.
Re: Avon Roadriders
Posted: Wed Dec 28, 2011 8:11 pm
by 1888
Cold Snail wrote:I've got one on the back of the 650.
Just in case its a bad batch mine was dated 0311 which i think means March 2011.
Re: Avon Roadriders
Posted: Wed Dec 28, 2011 9:14 pm
by nokatanayet
thats nasty :shock:
Re: Avon Roadriders
Posted: Thu Dec 29, 2011 11:54 am
by outrage
I got the same thing but with the front tyre. It was actually starting to go down and a long process for me to return so i just filled it with the tyre sealer/puncture repair. Really disappointed and not sure if i would buy them again seeing as im not the only one.
Re: Avon Roadriders
Posted: Thu Dec 29, 2011 7:45 pm
by 1888
My front was fine so i am keeping that. I stuck a battleax on the rear now. Dont know if it a good mix as when i changed the rear i stuck the bike away for winter.
Re: Avon Roadriders
Posted: Sat Dec 31, 2011 3:35 pm
by Katfish
Quite worrying really as I recently fitted a pair.
Re: Avon Roadriders
Posted: Mon Jan 02, 2012 1:13 pm
by Cold Snail
Just checked mine and it's fine at the moment.
Re: Avon Roadriders
Posted: Mon Jan 02, 2012 5:43 pm
by 1888
I think with general use you will be fine. My 1000 miles were two up with luggage. It seems to be the tyre pulling on the corners and with me having excess weight did not help. It should still not happen though. Just keep an eye on them.
