Page 1 of 2
Tech head needed
Posted: Fri May 04, 2012 7:00 pm
by Katman
I'm trying to set up a wireless router but I'm struggling to understand some of it.
So I'm gonna bug you lot for answers,
(if that's ok)?
OK 1st question, it's asking what type of connection I have
PPPoE, PPPoA, Static, DHCP, Bridge, CLIP
How would I find this out?
Re: Tech head needed
Posted: Fri May 04, 2012 7:16 pm
Most use PPPoA according to google Jez.
What router you got ?
Have you not used the wireless network wizard in windows ?
Posted: Fri May 04, 2012 11:41 pm
by Katman
I got a D Link DSL-G604T router & I've got it connected to internet but I can't make head nor tail of setting up security.
I bought this about 9 years ago & couldn't suss it out then...makes even less sense now
Posted: Fri May 04, 2012 11:54 pm
by Katman
OK when I try to set up a password (I think) it asks for "Enter 10, 26, 58 hexadecimal digits for 64, 128, or 256 bit Encryption Keys respectively. e.g., AAAAAAAAAA for a key length of 64 bits." WTF does that mean what are 10 hexadecimal digits????
Posted: Fri May 04, 2012 11:58 pm
by Katman
WTF??? Every wireless network I know uses simple passwords like family, royal blue etc etc. I've just googled hexadecimal digits & now I'm more confused then ever....now you really DO need to know rocket science!!!
Posted: Sat May 05, 2012 6:34 am
dunno - helps ?
http://www.warewolflabs.com/portfolio/p ... anskg.html" onclick="window.open(this.href);return false;
maybe dont use WEP. Use WPA instead - which i think gives you a "normal" password.
Only going by what i see on internet.
http://forums.whirlpool.net.au/archive/644200" onclick="window.open(this.href);return false;
Posted: Sat May 05, 2012 10:53 am
by lomsavage
Hexadecimal counts in base 16 as opposed to base 10
Hence 1 - 10 then a - f (a = 11 etc)
Similar to the way binary use 1 and 0 only
Posted: Sat May 05, 2012 10:56 am
Smart arse
And take that "for sale" shite off as well.
Posted: Sat May 05, 2012 10:58 am
by sparki
if it's 9 years old then it not gonna be nearly as easy to setup as the ones you'd buy nowadays.... todays really are plug n play... older ones you need to setup quite a bit..... if you want to easily setup a wifi network.... then enfore MAC filtering. That way you just stick your PC's MAC address (the number that is specific to the wifi adaptor in any device) into an exception list on the router and then anything NOT in the list will not be able to connect. simple. if your confused, this is the easiest way to secure it.
Posted: Sun May 06, 2012 6:30 pm
by Katman
I'm even more confused now Steve, think my best bet is to ditch the D Link & buy something newer...the only Mac filtering I know is me refusing to go in McDonalds
