Cheers, Adam
Engine cover decal removal
germankat
Anyone know a good tip for removing the engine cover decals? I have the correct ones to go back on and I want to polish some scratches out of the genny cover but I can't get the old decals off.
Cheers, Adam
Cheers, Adam
Re: Engine cover decal removal
sharp woodworking chisel and great care! its tricky but the only way. getting it hot will loosen the adhesive, but theyre stuck on well!
germankat
Cheers for that, I have already tried removing with a sharp impliment but not added the heat yet.
germankat
right, top tip for these things, leave to soak over night in sticky stuff remover, and it comes away no probs.
Off to the polishers then.
- jerry
- Has thanked: 6 times
- Been thanked: 8 times
So.........having just taken crankcase cover in for weld on small underside crack
, the guy said to me 'you realise that because this is done at such a high temp' the decal will bubble up and fall off' Ha Ha I thought........
Jerry
GSF 1200 K6 2006 Naked
germankat
I've been doing polishing at home for years now, horrible job, got the quote back today for all 4 engine cases, £40................. why have I been bothering to do it at home? let you know how good the results and then maybe a recommendation of local services list?
Where's that at?
You're only down the road from me
KOCUK 046 Jez
to be continued
to be continued
germankat
Hi Katman, the place is called Suussex Polishers or polishing, they are in Lancing. Haven't had the bits back yet so I am still not sure of how good the work is yet,but will let you know.
