Some of you might have allready done this
As a wider rear wheel is fitted with a 180 tyre, now the proper spacers are made and fitted, the chain run was off by 18mm so machined down sprocket carrier by 8mm, then fitted offset front sprocket and chain is now straight.
But 630 offset sprockets like hens teeth
So while i'm ok at the minute was thinking of getting a 530 chain conversion for next time, but as i have offset 17 tooth front and plenty of 530 chain, its the rear thats doing my head in
Or should i just replace both sprockets 15/42 but in 530 (can still get 15 offset front)
So if anybody has done it please point me in the right direction
oops sorry many thanks in advance
