Can't really figure out what you mean talking about inside/ outside edges of chainplates. But I take it your chain is running out by 2.4 mm in comparison of both sprockets and you're aiming to reach 0.4 mm by shaving the sprocket carrier?
I ran my old single wider Kat with a 180 mm section tyre on a 6" rim which made it necessary to allow some chain runout. Not ideal but safe. 2.4mm on that distance is no problem, will let the assy wear out a bit faster. 0.4 mm is close to none.
Chain runout
Re: Chain runout
lol, blix, take your rear sprocket off and flip it over! its machined on one side, so flipping it over will move the sprocket centre line towards the tyre by whatever the depth of the recess is. you may not need to pay someone to machine the carrier, because the sprocket is already machined on one side.
Re: Chain runout
ive done the same myself, i needeed 2mm and the sprocket had a 2mm recess, so i flippeed it over, job done.
