GS 650 Katana Side Panel: Broken Plastic Lug
craik
Has thanked: 70 times
Been thanked: 17 times
Post by craik » Thu Sep 12, 2019 7:09 pm
Hi,
One of the 3 plastic lugs attached to the LH side panel has broken off.
Is there any fix for this or is the only practical solution to locate a new side panel?
Thanks in advance for any advice.
Has thanked: 185 times
Been thanked: 734 times
Re: GS 650 Katana Side Panel: Broken Plastic Lug
Post by fossie » Thu Sep 12, 2019 7:17 pm
We used a place in Worcestershire that plastic welded our pop up project side panels back together, and I mean they were trashed.".... You couldn't tell.
I will dig out the info .
In the past years I have tried alsorts from plastic welding with cable ties to various adhesives, with varying results ......in future this is the route I will travel.
craik
Post by craik » Thu Sep 12, 2019 7:49 pm
Thanks Fossie. I had never even heard of plastic welding before. Just Googled a company near me that I could drive down to who claim they do it and will ring them tomorrow.
If I get no luck with them, will try your recommendation in Worcestershire.
Has thanked: 658 times
Been thanked: 249 times
Post by Uncle Bob » Fri Sep 13, 2019 8:57 am
Be handy to know the place in Worcestershire and also the name of the place Craik uses (and how he gets on). Again a service as time goes on that will be needed I guess.
As an aside there are some YouTube videos on how to do - might be worth getting some gash panels to give it a try!
craik
Post by craik » Fri Sep 13, 2019 6:27 pm
So far no luck with the places I tried.
Will contact the Worcestershire company if Fossie can dig up the details.
Post by fossie » Fri Sep 13, 2019 7:25 pm
http://www.plastics-surgery.com
01684311210 ...Steve . Mention the katana owners club pop up panel he did for us ....it was FOC because it was for a cause and advertising. Nice chap.
Post by PaulD » Fri Sep 13, 2019 7:28 pm
If you’ve still got the bit that snapped off you might be able to fix it.
I had the same thing on my Kettle, I super glued it back in place then drilled a small (1mm) hole down the Center and then glued a steel pin in the hole. It lasted the five years I had the bike and is still going strong as far as I know.
Rustynail
Has thanked: 21 times
Been thanked: 9 times
Post by Rustynail » Sat Sep 14, 2019 1:23 pm
If you identify what plastic the panel is and buy some plastic welding rods of the same type you can get some good results with the welder in the photo. This is a seat base I welded
craik
Post by craik » Sun Sep 22, 2019 10:40 am
Thanks all.
