Fueling issue
- Has thanked: 39 times
- Been thanked: 116 times
Re: Fueling issue
I know this isn't your problem, but always make sure you use the correct hose for the vacuum hose. Suzuki use a thick-wall double skinned pipe for the vacuum, presumably to prevent collapse.
Re: Fueling issue
Problem solved ! the metal prong had been mangled & was the cause of the stiff tap operation, new original spec tap from Ebay & the problems solved.
Appreciate the info , I’d never have know the prong should have been present without it
- Has thanked: 658 times
- Been thanked: 233 times
