550 charging system
Re: 550 charging system
Post by callyboy » Mon Aug 31, 2015 7:41 pm
i have a 550 speedo and rev counter holder thing with just the rev counter and centre light cluster Nicky. any good?
Has thanked: 136 times
Post by Nicky Dodds » Mon Aug 31, 2015 9:07 pm
Thanks for the offer pete but i've had both the clocks to bits and changed the needles, replaced all the shot bulbs in the gear indicator and got the speedo working again which in reality was just bent tangs in the drive.
Kill switch is wrecked and bypassed and pass switch has stopped working which i've not investigated yet. Both mirror mounts are u/s and need replacing. Otherwise the cockpit area is good, got some new cut down renthals and new grips on.
Post by Nicky Dodds » Thu Sep 03, 2015 4:47 pm
Meter arrived!
Looks like it's written in egyptian!!!
Post by callyboy » Thu Sep 03, 2015 6:53 pm
Only setting you need are the buzzy thing and the 12 volt thing ;)
what one you got? will tell you where to set it.
Post by Nicky Dodds » Thu Sep 03, 2015 7:23 pm
Excel XL830L
Big dial in middle, back light button, hold button, that's about it...
Post by callyboy » Thu Sep 03, 2015 7:41 pm
red bit at 5 o'clock is the buzzy thing ;)
top left voltage set to 20 is the volt thing ;)
simples :)
Post by johnr » Thu Sep 03, 2015 11:01 pm
dont buy a cheap crimper. buy a ratchet crimper. theyre not stupidly expensive, but not dirt cheap either. but you will own it forever.
Post by Nicky Dodds » Fri Sep 04, 2015 12:02 pm
Getting 13.5 when running at 2000rpm
Loads of ratchet crimpers on ebay, any particular ones to avoid john ?
Post by Nicky Dodds » Fri Sep 04, 2015 12:04 pm
Pete what did you have your air screws set at when you had your 550 ?
Post by callyboy » Fri Sep 04, 2015 12:23 pm
Blimey.......errrr think it was 3 and half. not 100% though.
