Ultrasonic cleaning
superfly
Re: Ultrasonic cleaning
Post by superfly » Fri May 06, 2011 6:24 pm
Ok lads,
I have the carbs bank in bits, I finally got arround it I had to drill the bolts. Jaysus they were tight.
I am having fun at the moment with the ultra sonic cleaner gret stuff.
I am wondering should I clean the diaphramg as well? or it is point less, and/or might damaged them.
Arnaud
Post by fossie » Fri May 06, 2011 7:47 pm
Leave the diaphrams out of cleaner, they are shaped and pliable, won't be after 1 hour in boiling water
superfly
Post by superfly » Fri May 06, 2011 8:49 pm
ok cool thanks, that is what I thought.
Hopefully I will put it back together on sunday or monday, and synchronise the carbs and it will run like a dream.
superfly
Post by superfly » Mon May 09, 2011 12:18 pm
arf I did start cleanning the carbs, but the ultrasonic just broke...
I hate those thing you buy them a good amount of money use it 2 time and it broke.
It is a bit sh%^&*(te....
I am going to put back the carbs together all this waiting on the ultrasonic for such result....
Post by callyboy » Mon May 09, 2011 1:14 pm
What happened to it ? Do you know ?
What a shame.
Post by Katgeezer » Mon May 09, 2011 3:18 pm
Did you suspend the stuff you were cleaning as you mustn't just lay stuff in the bottom, it must be either in a basket or suspended on wire.
superfly
Post by superfly » Mon May 09, 2011 7:46 pm
It was in the basket it just stopped !!
I reckon the machin got to hot and burnt somehow. :-/
I am going to call the manufacturer tomorrow and see if I can get a replacement or a refund.
