550 carbs
superfly
Re: 550 carbs
Pete, I don't see on the second picture where is the choke?
Could you take one wider?
I bet you need a cv joint to get there, could you show me on a wider one where is the choke and the nut adjuster?
Re: 550 carbs
Watcha Arnaud, the choke assembly is next to the throttle. You can see the cable coming into the pic. It looks white in the pic.
Off down to the car shop for a deep offset spanner !!
superfly
Re: 550 carbs
Pete,
Maybe get something like that http://www.ebay.co.uk/itm/Deep-Shallow- ... 616wt_1166
I got something similar for €12, one day and it is very usefull.
I try to find you back the link but no luck so far.
superfly
superfly
Re: 550 carbs
yeah pete, if you don't have one of those definitely go for something like, I use it all the time probably more then the spanner.
Re: 550 carbs
See page 5 - Yep. Got one of those - works great on the 2 outside ones. It will not get to the centre one. There is no way to get to it from the top. The frame bracing gets in the way. If you go inbetween the bracing it puts the tool at an angle and then you cant get on the nut square. I am going to get a deep offset spanner and go in from the side I think.
