Page 1 of 2
Petrol tap gaskets
Posted: Wed Jan 12, 2011 9:05 pm
Have to swap over my petrol tap onto another tank and was wondering if there is a cheaper way to do the gaskets than the £15 odd quid the kits seem to cost. Not a huge amount, but its all adding up :( is there a petrol friendly liquid gasket ?
Re: Petrol tap gaskets
Posted: Wed Jan 12, 2011 9:28 pm
by Cold Snail
Be gentle and you wont need gaskets.
Posted: Wed Jan 12, 2011 9:42 pm
Watcha Paul.The small ones that were on the two bolt holes just fell apart. The large one that runs round the outside looks ok. albeit a bit flat and hard( as opposed to rounded and soft !!!).
Posted: Wed Jan 12, 2011 10:02 pm
by bobster
Pete and gentle in the same sentence! Thats a new un!
Drop me a PM with your address and I will send you some dowty seals for the 2 bolts.
Try boiling the larger main tap seal in Boiling water to make it more supple!
Oh and Dont use gasket sealant m8!
Posted: Sun Jan 16, 2011 5:24 pm
by bobster
Here you go Pete!
http://cgi.ebay.co.uk/SUZUKI-GS-1000-85 ... 3364280548" onclick="window.open(this.href);return false;
Posted: Sun Jan 16, 2011 7:10 pm
Cheers bobster.
Not quite the same as mine. Mine dont have the cross connection bits. just straight seal all way around.
bit like this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _500wt_922" onclick="window.open(this.href);return false;
Thanks anyway mate.
Posted: Mon Jan 17, 2011 5:39 pm
green hermetite, seals petrol taps and doesnt get disolved. just let it dry before filling the tank ive used it on tank seals and also carb float bowl rubbers.
Posted: Mon Jan 17, 2011 6:29 pm
Watcha John, cheers for that info mate. I have bought some Loctite lock and seal for the bolt threads(couple of quid). Some dowty are being sent from bobster (unless he's forgot !!) . Will get some of that green hermetite as well.
Posted: Tue Jan 18, 2011 7:34 am
by bobster
Seals are in the post m8....i couldnt find any 6mm ones so have put 1/4" ones in the package..........they are slightly bigger but should still do the job!
"some people call me the space cowboy"........................"some call me the gangster of lurve" :lol:
Posted: Tue Jan 18, 2011 8:04 am
some people call me Maurice- Whaaaaa whaaaar :)
Cheers Bobster.
PS - Hermetite have gone bust ?
