Page 1 of 2
ignition wont turn
Posted: Fri Dec 02, 2011 10:24 am
by askinmechanic
hello all, went to try and start the pop up yesterday and the key wont turn ! pushes in ok and when i try to turn it the steering lock moves but will not retract all the way so i can get her running, any ideas what i can do other than bin it ! and does anyone know if the gixxer ignition wires are the same because i have one with a key in the shed somewhere, i know the plug is different but i can swap the wires into the old plug me thinks, all help apreciated.
steve
Re: ignition wont turn
Posted: Fri Dec 02, 2011 10:34 am
by Katgeezer
First thing I'd try is soaking in WD40 or some other spray penetrating lube for a day or so to see if it frees off. Put the tip of your key in the lock to open the flap then just let fly with a good squirt (oo-er missus).
Posted: Fri Dec 02, 2011 10:39 am
by nokatanayet
take it off and give it a good soak with wd40, if its really stuffed then remove the barrel and just start the bike useing a screwdriver in the switch.
i would think that any gsx750 e,es,ef model should work on your bike.
good luck steve
Posted: Fri Dec 02, 2011 10:40 am
by nokatanayet
Katgeezer wrote:First thing I'd try is soaking in WD40 or some other spray penetrating lube for a day or so to see if it frees off. Put the tip of your key in the lock to open the flap then just let fly with a good squirt (oo-er missus).
you beat me to it chris ;)
Posted: Fri Dec 02, 2011 10:52 am
by askinmechanic
right its soaking in wd40 ! and i have dug out the gixxer one from the shed just incase, as i have to work on it outside at the moment i really want to see it running before it starts snowing lol, i will report back after the weekend...
Posted: Fri Dec 02, 2011 1:14 pm
by uber pikey
the ignition block is a green plastick block connector which fit a lot of the early Suzukis however I think that the units are slightly different and are worth doing a little research first.
Posted: Fri Dec 02, 2011 2:00 pm
There is one on ebay at the moment, but its pricey :shock:
http://www.ebay.co.uk/itm/Ignition-Swit ... 1824wt_897" onclick="window.open(this.href);return false;
Posted: Fri Dec 02, 2011 2:40 pm
by askinmechanic
does anyone have a wiring diagram showing what is what on the pop pup green connector ?
Posted: Fri Dec 02, 2011 2:41 pm
by askinmechanic
callyboy wrote:There is one on ebay at the moment, but its pricey :shock:
i didnt pay much more than that for the whole bike :lol:
Posted: Fri Dec 02, 2011 7:04 pm
by nokatanayet
steve, go into the members room, half way down it will say workshop manuals, it will tell how you can down load the whole manual for FREE :D
