Ignition Lead same as on a car?
Posted: Sat Apr 28, 2012 12:00 pm
by superfly
Hi lads,
I am doing the bike at the moment, and I really that 2 leads could be part of my problem.
I am thinking about going to the motor factor and get some car one, are they the same?
Re: Ignition Lead same as on a car?
Posted: Sat Apr 28, 2012 12:16 pm
by FBJ
Hi, if there stock coils no! However you sused to be able to cheat, aint done it for years but you used to be able to buy smaller supressors, like a thing with a screw on each end, then you could buy a length of cable and fit it, I'd be suprised if the leads are your problem
Posted: Sat Apr 28, 2012 12:29 pm
Make him an offer - In Ireland to. Always good to have some spares
http://www.ebay.co.uk/itm/SUZUKI-GSX400 ... 1316wt_754" onclick="window.open(this.href);return false;
Posted: Sat Apr 28, 2012 12:33 pm
or just the one set:
http://www.ebay.co.uk/itm/SUZUKI-GSX400 ... _500wt_716" onclick="window.open(this.href);return false;
Posted: Sat Apr 28, 2012 1:59 pm
by superfly
They are just screw on type, I was about to buy a length to be honest and cut on demand.
Why are they different then a car one?
I screw back 2 of them and got the bike to start on the spot on, they were held by silicone...
I think it is all it is require no, as long as the size is the same it should be no matter?
I had to cut to insitu this properly, so it is a bit short so I thought I need to get some new one.
http://www.ebay.co.uk/itm/Black-HT-Igni ... 085wt_1166
I am half way to clean and rebuilding the carbs, I have to go and mind the kids mate now
So I will finished it up tomorow.
