Page 1 of 2
popup flywheel removal
Posted: Tue Feb 01, 2011 1:31 am
Now forgive me but I thought I'd asked this before but there has been no replies which I found unusual, now I can't find the thread so either I wrote it somewhere else or I dreamt it!!!!! :shock:
Anyway forgive the duplication if it is so . :lol:
I need to extract the flywheel (rotor)from the crank, It isn't very impressed and is as stubborn as my daughter on a mule! :twisted:
What I need is a flywheel puller for a 750 se/es However I suspect it may be common.
We need to show it restistance is futile. :P
Has anyone got one I may borrow.
Re: popup flywheel removal
Posted: Tue Feb 01, 2011 5:15 am
by dave309
is it the same as the 1100 puller
Posted: Tue Feb 01, 2011 10:22 pm
Not 100% sure but can't see why it wouldn't work.
Posted: Wed Feb 02, 2011 6:43 pm
by dave309
got one can post if you want
Posted: Wed Feb 02, 2011 9:46 pm
That,ll get great Dave, I'd come over to collect it but the shift system, negates that at the mo.
Let me know how much postsge.
Posted: Wed Feb 09, 2011 12:34 am
Dave309 kindly came ver to mine on Sunday with 1100 puller.BUT it doesn't fit sadly, the thread on the 1100 is 34 mm and we need 30mm,
Any ideas?
Posted: Wed Feb 09, 2011 1:00 am
by bobster
I will see if I can get one made at w0rk.........what is the pitch of the thread? is it 3mm?
Does it just need to screw on to the flywheel and have a H/Tensile bolt threaded to screw against the end of the crank.
And with a couple of flats machined in the body of the puller to hold with a big spanner.
Do you have a pt nos for the correct puller as I may be able to borrow one to copy!
Posted: Wed Feb 09, 2011 1:08 am
Bobster my man your desciption in both correct and eliquent.
Iwill seee if the part number is in manual tomorrow. Ta!
Posted: Wed Feb 09, 2011 3:35 pm
by JACKJABBA
Is it like this.
http://cgi.ebay.co.uk/Flywheel-Puller-M ... 144wt_1135
Maybe we could have one in the clubs tool section?
Posted: Wed Feb 09, 2011 4:20 pm
by sparki
think the thread is on the wrong side of the doo-hickey in that one
