Engine paint
Russbusa
Engine paint
Post by Russbusa » Thu Feb 03, 2011 11:35 am
I know i'm probably digging up an old thread :oops:
Were the gs engines painted silver from new or bare aluminium ?
The 2 I have here look to have been painted very badly and dont appear to have a good factory finish under the crap thats on top. I was going to get the whole engine vapour blasted but dont see the point if it should be painted again as a normal bead blast is half the price.
£140 for crank cases, barrels, head and cam cover. cleaned, stripped and vapourblast, does this sound abpout right ???
Cold Snail
Re: Engine paint
Post by Cold Snail » Thu Feb 03, 2011 12:15 pm
Talk to JohnR about acid dipping.
Re: Engine paint
Post by sparki » Thu Feb 03, 2011 1:14 pm
dipped is preferable imho..... COMPLETELY clean when you get em back with zero blast material left behind (obviously)
speak with johnr nicely as he has a place en route to work that'll do a stirling job ;)
lomsavage
Has thanked: 3 times
Been thanked: 28 times
Re: Engine paint
Post by lomsavage » Thu Feb 03, 2011 1:15 pm
Blix wrote:Is that swimming when your high then ;-)
that's a mis spent youth mate
or not as the case may be
:lol: :lol:
Hello from H
Re: Engine paint
Post by bobster » Thu Feb 03, 2011 2:20 pm
I think only the top crank cases , cylinder and head were painted silver Russ.
Vapour blasting doesnt leave any possible detritis in any of the oilways like bead blasting could!
I used good old elbow grease on my crank cases when i did mine!
http://s579.photobucket.com/albums/ss23 ... =334-1.jpg" onclick="window.open(this.href);return false;
Did anyone ever tell you NOT USE PJ1 SILVER.......it goes YELLOW... ;)
Re: Engine paint
Post by sparki » Thu Feb 03, 2011 2:37 pm
vapour blasting still uses solid media in addition to water
Re: Engine paint
Post by bobster » Thu Feb 03, 2011 2:41 pm
" Get the F*ck outta here"
Does it?
well I never...........you learn something new everyday!
JACKJABBA
Re: Engine paint
Post by JACKJABBA » Thu Feb 03, 2011 3:23 pm
Thats a clean looking engine Bobster. So which paint is best to use, other than PJ1, as I will be doing this in the next month.
Regards Jack
GSX1100SZ
RD500LC
RD250LC
VF1000R
KE 125 1976
KOCUK 316
Re: Engine paint
Post by bobster » Thu Feb 03, 2011 4:35 pm
I used CARPLAN VHT.....but it needs curing first ,and can get washed off with petrol and solvents, if youre not careful.
Doesnt go yellow though!
Cold Snail
Re: Engine paint
Post by Cold Snail » Thu Feb 03, 2011 4:40 pm
Bob.
You could have sprayed that towbar while you were at it, look at the state of it.
