FBJ
- Has thanked: 5 times
- Been thanked: 31 times
Post
by FBJ » Sat Jul 28, 2012 6:55 pm
Hi all. Gutted. Just fitted a rock to flo kat when disaster struck. Just pulled threads of top shock mount. Anyone done it? If so what ya do to fix it? Tap and die ?
Post
by johnr » Sat Jul 28, 2012 7:03 pm
not what you want to hear, but i built it up with silver solder and then cut a thread on it/ as a temp measure you could put a hole through the nut and shock mount and secure it with a split pin.
dave309
Post
by dave309 » Sat Jul 28, 2012 8:22 pm
hapened to me once drilled a hole in end of the stud and nut then used a self tapper through both
Nigelkat
- Has thanked: 1 time
Post
by Nigelkat » Sat Jul 28, 2012 9:27 pm
Devcon chemical metal, good temp repair did it on mine few years ago before the rebuild, then did it properly, replaced stud.
Post
by bobster » Sat Jul 28, 2012 9:45 pm
Ham fisted fekker.........
Weld up the damaged stub, grind back to tapping size and then re-tap the thread, think the thread is M10x1.25 pitch.
And then get some shorter spanners!
Post
by bobster » Sat Jul 28, 2012 9:51 pm
Or
....................you could get an 8mm Timecert and fit that to the damaged stub after re-tapping the stub to 8mm and then the outer thread will be back to M10.................but you'd have to fit a couple more washers and file off the shoulder on the timecert.
Think that would work!
http://www.google.co.uk/url?sa=t&rct=j& ... fR0m-1dLRQ" onclick="window.open(this.href);return false;
Post
by bobster » Sat Jul 28, 2012 10:08 pm
Or
Tap the damaged thread to 8mm and fit the 8mm time sert inside the dome nut, using some high strength loktite..........that would also work....but you'd always have to use the modded nut on the smaller thread!
FBJ
Post
by FBJ » Sat Jul 28, 2012 10:29 pm
I like that idea. Will spend some wedge tomorrow on a tap n die set
