compression problem
tomtom
compression problem
Post by tomtom » Mon Oct 29, 2012 11:16 pm
I used a Cometic sprung steel head gasket on my 1100 about 3 000 miles ago after a full engine rebuild. Everything great then bike won't start one day. Did the usual checks and no success. Checked the compression and it was way down on 3 cylinders beyond usable. Have the head off and no holed pistons thankfully but has anyone come across such a short lifespan of these gaskets. It's only used on the road. Are copper gaskets better. Thanks.Any other thoughts would be helpful.
Been thanked: 198 times
Re: compression problem
Post by Pedda » Tue Oct 30, 2012 11:21 am
Sprung steel gaskets are excellent. I don't suppose it to be the reason for your loss of compression. I'd check valve seats or rings.
Post by Katgeezer » Tue Oct 30, 2012 11:48 am
Agree with Pedda, Cometic are among the best there is altho' for a standard engine most would probably use OE gasket as the Suzook ones are brilliant. Can't imagine the gasket being the problem.
Rings or valve gear most likely.
Were you using much oil when it was running? I presume you didn't disappear in a cloud of smoke every time you pulled away.
tomtom
Post by tomtom » Wed Oct 31, 2012 6:37 am
Valve stem seals and new rings and bores honed only 3000 miles ago. Was working one day and not the next. Surely a bit too much coincidence if compression is suddenly down on 3 out of 4 bores. Scratching my head on this. Any other ideas please.
FBJ
Has thanked: 5 times
Been thanked: 31 times
Post by FBJ » Wed Oct 31, 2012 7:01 am
Tomtom. Turn the head up side down and fill the valve pockets and see how quickly it leaks out.
Post by Katgeezer » Wed Oct 31, 2012 12:44 pm
So you're happy the basics are ok so maybe we need to go deeper.
How about the camchain tensioner,does it seem to be ok? Thinking jumped tooth here guys, anybody else agree?
Post by Pop-Kat » Wed Oct 31, 2012 5:26 pm
Can't see it being the cct chris.
If you use a copper head gasket you really need to have the block piano wired to seal in compression, it'll work good then but you might suffer annoying oil leaks. Use a std gasket if your on std bore. As for your compression problem, is your tester good ? Are the plug threads good ? It could have just flooded (fuel tap diagram) then a non accurate test shows low comp. not saying that's what's happened, just offering possibilities.
Post by bobster » Wed Oct 31, 2012 7:34 pm
In some cases when the piston rings are all aligned with all the gaps in the same area of the piston, it can show a low compression reading...........Did you re-torque the head down and then do a DRY and then a WET compression test ( Wet being with a squirt of oil down the plug hole) Throttle should also be held fully open when you do a compression test with all plugs removed and with a fully charged battery in good condition!
The steel head gasket should be re-usable if not damaged in any way and once you have cleaned it and given it a spray with some VHT paint........which will cure on warm up of the engine!
