valve clearance tool.
Where is the cheapest place to get a wee tool for doing valve clearance. One that fits the small square on the adjuster. Thanks.
- Been thanked: 716 times
Re: valve clearance tool.
Touch'e. Yep both correct we have the tool for both types shims and screw and lock nut , free hire to club members.
Otherwise as sparki says robinsons genuine or a set of 4 multipack , different sizes. from M&P
- Has thanked: 638 times
- Been thanked: 243 times
I think you want Part Number: 09917-14910. Found one here for £5.99!
http://www.discountbikespares.co.uk/our ... 0600F.html
Probably more in postage!
Looks the same as the one I have.
- Has thanked: 120 times
Is there one of those ratchet type that will fit the Kat engine?
I"be seen some that give a thou per click so you can do without the feeler gauge s
