Left hand engine case, what others fit ?
Post by Pop-Kat » Wed Nov 28, 2012 10:41 pm
Looking for a spare generator cover for the racing Kat, I know the generators smaller but are the covers off the gsx1100 the same and are the Kat/gsx750 covers also the same ?
KeKat
Has thanked: 3 times
Been thanked: 44 times
Re: Left hand engine case, what others fit ?
Post by KeKat » Thu Nov 29, 2012 4:58 pm
No for both
Only a 1000/1100 SD/SZ will fit.
You need the one with 4930 stamped on the inside, next to the generator guide.
Keith KOC 355
1982 Suzuki GSX1000SZ
1991 Ducati 900SS
1996 Kawasaki ZZR600
2003 Transalp
2004 MV Agusta brutale F4
2003 Cagiva xtra raptor 1000
2012 Triumph Tiger 800
2019 Suzuki GSX-S 1000S
KeKat
Post by KeKat » Thu Nov 29, 2012 5:03 pm
I bought a pair of these to protect my gen cover. Half the price of a new cover.
http://flatracer.com/#/crash-bars-suzuki/4543536082" onclick="window.open(this.href);return false;
Keith KOC 355
1991 Ducati 900SS
2003 Transalp
Post by Pop-Kat » Thu Nov 29, 2012 5:27 pm
Cheers for the info Keith, Don't think those crash bars will help ground clearance :lol:
Need a spare cover as going to cut a bit off the lower edge and plate it for more clearance, assuming there's enough room to the generator.
SO, anyone got one i can have ?
Post by bobster » Thu Nov 29, 2012 5:35 pm
Hi Mal
Will your 1000sz racer have the genny fitted or will it be a total loss system to save on weight. If the latter then all GSX1100 cases will fit.
If you are running a geeny you'll need a casing with 4930 stamped on the inside just as KEKAT says...........but getting quite rare now.
Did KEKAT throw his old one away?............if not maybe it can be repaired and strengthened for use on the track!
I may still have a slightly damaged one in my collection....... ;)
Post by Pop-Kat » Thu Nov 29, 2012 5:50 pm
Hi Rob, I think we're running the geny, as it's production class. a damaged one will do as long as it's not totalled. scuffed up or small hole is ok, cheers.
The bikes an 1100 btw.
KeKat
Post by KeKat » Thu Nov 29, 2012 9:51 pm
I will take a photo of my old one, so you can see the damage. i will post it to you if you want it.
Keith KOC 355
1991 Ducati 900SS
2003 Transalp
KeKat
Post by KeKat » Thu Nov 29, 2012 10:01 pm
Here it is
Keith KOC 355
1991 Ducati 900SS
2003 Transalp
Post by bobster » Thu Nov 29, 2012 11:10 pm
Mines a bit better than that Mal :shock: But even that'll repair with a bit of alloy welding ;)
i'll see if i can dig it out, just cant remember where I saw it last...............It has a slight dent and a small crack, a bit like me :lol:
Post by Pop-Kat » Thu Nov 29, 2012 11:44 pm
That would be great if you could dig yours out Rob, sounds ideal :D
Keith, how much do you want for postage, Yours could be handy to use to make a plate for Robs one, or maybe it will repair if i show it to a welder.
To have them both will cover all bases, thanks guys :D
