400 carbs information
Posted: Tue Mar 08, 2011 1:13 am
I know the title seems very formal but , I think it's something we should know about , well I do now , and so will you .
History; My 400 started to run a touch unsteady , it was always a bad but reliable , ( By which I mean I know the sequence)
No this was something else a stutter when I thottled off and the revs dropped below 5000ish. Overfueling?/Coil?
Check coils and Ht leads new plugs , found split in vacuum pipe, --Better but no cure.
Stuff it carbs off check for stuck float.
Spoke to Andy at NRP who showed me some needles from a Bandit, apparntly they wear , at the topas it enters the emulsion tube , so do GSXR ones and many others . It turns out the new needles are not coated like the old ones and modern fuel eats them.
So I went to look at mine but couldn't get the float bowls undone (They have never been off)
Gave the job to Alan in the bike shop up the road .
This is what was revealed. This shows what was wrong, 3 needles worn like the left one 1 completely snapped with the needle in the emulsion tube , hence the working at full throtttle
This is what it should look like.
This is to show that the nick looks almost machined in but is worn away
I know my 400 is higher milage than usual but it's only 110,000 km's
but at 10,000rpm I suppose.
As a foot note Alan ultrasonicly cleaned the carbs refitted all jets and new needles I swiped fronm the 250 (for now) all for £50.
