Russbusa
Post by Russbusa » Sat Mar 12, 2011 8:48 pm
If you've ever snapped a tap or stud extractor in aluminium you'll know you have a big problem, you cant drill out the offending piece as its way too hard.
If you can get the offending stud/hole facing upwards or chemical metal yourself a little dam around the hole, Nitric acid will eat away enough of your broken tap or stud extractor in about 20 minutes to remove it and not damage the aluminium. Saw this done last week, simple way to get out of a really big problem and way cheaper than spark erosion.
Been thanked: 198 times
Re: ????
Post by Pedda » Sun Mar 13, 2011 10:31 am
Interesting. I'm sure time will come to test that method...
Fastasfowey
Re: ????
Post by Fastasfowey » Sun Mar 13, 2011 3:54 pm
Interesting stuff acid !
Uric acid is excellent at cleaning polished ally rims! My ZX12R had an unexplainable 'brake fluid leak' on the right front caliper for weeks, but never lost pressure or fluid!
One day I caught the vicar's dog peeing on my front wheel and realised it wasn't me going mad! Wouldn't have guessed as it's a bitch and didn't know they cock their legs too?! Well, I kid you not...that side always polished up a treat .
NOTE TO SELF............pee on bike on way home from pub!!! ;O)
Re: ????
Post by Pedda » Mon Mar 14, 2011 12:06 am
Ha ha,
that teaches you buying a Kwak!
Re: ????
Post by bobster » Mon Mar 14, 2011 7:38 am
Fastasfowey wrote:Interesting stuff acid !
I have to disagree with you on this one Mark. ;)
Being a long suffering Gout sufferer...............Uric Acid is the Bain of my life! :lol:
If you have ever suffered from Gout you will know that it's a 10/10 in the pain stakes.......especially if it's in your feet!
And contarary to popular belief it's NOT a "Rich mans disease".....cos I aint rich!
Doctor said i'll be alright if I keep taking the medication..............everyday for the rest of my life :shock:
Russbusa
Re: ????
Post by Russbusa » Fri Mar 18, 2011 8:57 pm
If you have the white furry aluminium fungus, use phosphoric acid @ 5% and watch it run away and your ali goes bright ,,,,,,,,,, while your at it put some on your rusty steel parts and your rust turns into iron phosphate.
Phosphoric acid @5% strength Jenolite !
Re: ????
Post by callyboy » Fri Mar 18, 2011 9:50 pm
Watcha Russ, was wondering....my wheels have a white "bloom" on the black paint and was wondering if this stuff would get rid of it. I am going to paint at some point but not for a while yet.
what ya reckon ?
Russbusa
Re: broken studs/cutters/taps in aluminium ????
Post by Russbusa » Fri Mar 18, 2011 10:23 pm
If you get the wheel clean spray from your £1 shop, look up the safety data sheet from the manufacturer and voila - phosphoric acid !, I just happened to aquire a litre of 70% concentrated stuff from ummmm errrrrrr somewhere I frequent
Jenolite rust remover/killer/converter is between 2 - 5 % with water, plenty strong enough to remove the white fungus, dont soak cast aluminium for more than a few minutes or you will end up with a black smut on the surface (same as caustic soda leaves) the smut can be removed with nitric acid though !
You get the smut because the phosphoric or caustic has removed the pure aluminium and left the impurities like copper, silicone etc on the surface. Read up on anodising aluminium and you will get the full story if you really want it. . . . .yawn 8-)
Re: ????
Post by johnr » Sat Mar 19, 2011 7:26 pm
too much pate and port bobster !!!!!!!
