Spoked Wheels
Posted: Tue Apr 23, 2013 4:48 pm
Right hopefully someone can answer my question.
Which is: Why?
People with a long memory will recall that I do actualy have a Katana and I am in the process of rebuilding it (Stop sniggering at the back!) for the purpose of riding it on the road.
Now the only major modification/deviation from standard is that of replacing the original cast alloy wheels with a set of spoked GS750/1000 items.
So far so good. Front end sits absolutlly perfectly in the forks brake carriers/calipers lined up no issues about having to force anything to fit. So I'm happy with the front end.
Rear wheel is another matter.
originally when I got this set of wheels they were said to be off a GS1000, so when I fitted them with the spacers in the order Mr Suzuki intended it all went well until the rear caliper was dry fitted. I then had an issue getting the caliper on, in fact it would not fit at all as it was spaced too close to the disc. I discovered that thers is what Suzuki call a "Shim" behind the disc on the spoked wheel GS's. All fitted fine then.
But I did not realise until recently that there was another problem. When looking at the bike from the rear it became obvious that there was something out of alignment. I have looked at every thing I can think of, and tried one or two different routes to find out where the fault is.
I have even gone as far as buying another set of spokes off Steve White (Cheers Steve) to slot in and see if they improve the line up. But I still have the same probs.
I'll post up some photos of what I have and some more info.
Which is: Why?
