help ufgent opinions please
Post by Pop-Kat » Fri Jun 14, 2013 4:02 pm
I'm at cadwell, the oil light keeps flashing, changing down at high revs, accelersting hard from low speed and over the mountain, shoulf i race it like it ?, what could be the cause ? the oil level is on mac...
Also clutch is slipping for first couple of laps, got no heavy springs but habe got some new ebc plates i could put in, what to do ????!
Cheers.
Has thanked: 120 times
Re: help ufgent opinions please
Post by Kryten » Fri Jun 14, 2013 4:19 pm
Oil light could be a faulty connection.
Not sure the oil would slop about that much in the sump even at race speeds. Would it?
Post by callyboy » Fri Jun 14, 2013 4:20 pm
Is it still running hot as well still ? I think the 3 might be related. If its running really hot then the oil would thin down? Slipping clutch as well might be oil related if its hot.I dunno, just a guess. What oil you got in it?
Post by sparki » Fri Jun 14, 2013 4:24 pm
oil light could be strainer, but i guess that would have been cleaned out when built?, faulty switch /switch spring?
clutch plates... were they soaked in the oil before installing... 24hrs is best. steels scuffed up or new?, if they're smooooooth that isn't going to help... failing which stiffer springs
kiwi k
Post by kiwi k » Fri Jun 14, 2013 6:01 pm
Best clutch plates for Suzuki's are oem, there's not many good reports for ebc/other aftermarket plates, was going to suggest dodgy connections or switch, but the race or no race option is your choice, if it was me i would not until i'd checked possible causes out (switch,oil pump,blocked strainer)
IMO its expensive if you kill the engine thru oil related problem, as starvation destroys metal parts like cams + bearings.
But it's your choice
FBJ
Has thanked: 5 times
Been thanked: 31 times
Post by FBJ » Fri Jun 14, 2013 6:08 pm
I have it happen twice. First time was the strainer. Second was the wiring to the oil light light it was earthing out
Been thanked: 198 times
Post by Pedda » Fri Jun 14, 2013 7:16 pm
Slipping clutch is annoying when you're racing and asking high revs. Sometimes the clutch drags better when hot. If not, like sparki says, soak your new plates in oil over night and use these.
Post by bobster » Fri Jun 14, 2013 9:46 pm
You could always put a single flat washers underneath each clutch spring to add more pre-load on them. Or just put 3 in (every other spring). This is the cheap fix!
Ive Not heard good things about EBC clutch plates.
Ill second FBJ ...........Did u Check the oil strainer for crud when you had the engine in bits?
Post by Pedda » Sat Jun 15, 2013 9:34 am
bobster wrote:You could always put a single flat washers underneath each clutch spring to add more pre-load on them. Or just put 3 in (every other spring). This is the cheap fix!
That's the point! Do not locate the additional washers just beneath the bolts' heads, they won't do nothing there. So you need washers with a inner diameter as big as the springs'.
Post by Pop-Kat » Sat Jun 15, 2013 10:46 am
Thanks guys, tried washers and didn't work, got hold of dome heavy springs and put three in, hopefully ok, added a bit more oil and will see how it goes.
