Page 1 of 2
chain to tight?
Posted: Mon Jul 08, 2013 1:21 pm
Getting a bit of a noise when i am starting off. Sounds like the chain clunking on something. Too loose or too tight or even just plain old knackard?
Re: chain to tight?
Posted: Mon Jul 08, 2013 1:45 pm
by Katgeezer
If anything then probs to loose. Sit on the bike and see how much the chain lifts up and down, should only be an inch at most.
Failing that I'm afraid it's check everything's tight as usual!!!
Re: chain to tight?
Posted: Mon Jul 08, 2013 2:07 pm
by sparki
same chain / sprockets as before it was stripped? presume the clearance is ok and there isnt some minute front or rear sprocket where it scrapes across swingarm pivot?
Re: chain to tight?
Posted: Mon Jul 08, 2013 3:58 pm
Same sprockets and chain Steve. Thought i had adjusted chain ok but will have another look. Was thinking the chain might be knackered.
Thanks guys.
Re: chain to tight?
Posted: Mon Jul 08, 2013 5:55 pm
slackened it off a bit as it was a bit tight. Test ride tommoz to see if it helps. How much side to side movement should there be? seemed to have an awful lot of it.
Maybe should have checked it when it was off the bike. - another thing i forgot!!!
Re: chain to tight?
Posted: Mon Jul 08, 2013 7:21 pm
by Pop-Kat
If you can pull it off the back of the rear sprocket and see daylight between chain and teeth then it's knackered. Also have you checked for tight spots, chain should always be adjusted at the tightest point, then if other parts are really slack again it'll be knackered.
Re: chain to tight?
Posted: Mon Jul 08, 2013 7:47 pm
cheers Mal. Might have to get me one of those fancy paddock stands ;)
Re: chain to tight?
Posted: Mon Jul 08, 2013 10:33 pm
by Pop-Kat
Where's your centre stand ?, even if it doesn't fit with the pipe it only takes seconds to put it on and use a couple of allen keys or similar to slide through the bolt holes for maintenance purposes.
Re: chain to tight?
Posted: Tue Jul 09, 2013 6:37 am
Not got one Mal :(
Re: chain to tight?
Posted: Tue Jul 09, 2013 7:24 pm
by Pop-Kat
Get one off the vulture, i'm sure he has many in stock :lol:
