sprocket
Re: sprocket
Yes if you took it off in one piece (swing arm out) then you could put it back the wrong way, then all the wear is on the wrong bits.
Have you tried all these
chain alignment with a straight edge along the chain ?
tight spots
pulling the chain off the back of the sprocket (on slack spot and tight spot)
rear sprockets on the correct way around
the spacer behind front sprocket is still there
tight spots
Re: sprocket
Watcha Mal,
was off in one piece.
have checked the alignment.
checked for tight spots.
pulled chain on back of the sprocket.
didnt take sprocket off.
not looked to see if spacer is there.
Does that sprocket look too worn?
- Katgeezer
Re: sprocket
Hard to tell mate. Shape looks ok but the edges look worn over, odd. Can't imagine that's your clunk tho'. More likely the chain itself now. Tbh, a new chain and sprocket set is probably the best option in the long run. Start saving....
Re: sprocket
Cheers Chris, looks like it doesnt it
Might get a fancy gold coloured one
Sure everyone on here would like that eh
Any make better than others? Bearing in mind i do very little miles and dont ride fast
Re: sprocket
Are you coming down to wusseykat Pete ?, if you want a chain and sprocket kit I can get one for you, in gold of course
Pm me if you want prices
Re: sprocket
Cheers Mal - will let you know. tbh i may get my mate to do it down the bike shop. Not in mood for mechanics at the moment. Got enough on my plate at the moment
- Has thanked: 53 times
- Been thanked: 198 times
- Has thanked: 120 times
Re: sprocket
callyboy wrote:well ya gotta aint ya
Well I cannot say too much as I bought a C&S kit off weEvil BAY for Skruffy Kat
When I opened it up and took it out of the wrapper, I felt it ought to belong to a Rapper
That is soooooo 80's like innnit n 5h1t
