Post
by callyboy » Sun Aug 25, 2013 4:40 pm
Bit of a problem today
Went out for a spin on the pop up and needed some fuel. Started filling up and had a nice pool of petrol under the bike!!
Soon as i stopped filling up it stopped !!! Am sure i had the nozzle in far enough not for it to have been the drain hole at the top of the filler hole. Couldnt work out were it was coming from either and by the time i got home there was no trace of where it was coming from.
Any ideas?
- Been thanked: 716 times
Post
by fossie » Sun Aug 25, 2013 9:36 pm
If the bike started all right straight after filling up then I wouldn't worry, the only way putting fuel in and it draining out under the bike, other than the drain outlet ,would be if the floats stuck and the fuel went in to the air box. But that would also send fuel into cylinders. Leading to hydraulicing.
Post
by callyboy » Sun Aug 25, 2013 10:05 pm
Thanks Fossie. What about the drain tube from the top of the filler cap. Do these ever split inside the tank? Am thinking that if its cracked and the fuel gets to a certain level in the tank when filling, it will go into the tube and exit under the bike????
It started just fine.
Post
by callyboy » Mon Aug 26, 2013 3:59 pm
Just blew up the drain pipe whilst holding my finger over the hole at the filler end. seems ok. lots of pressure no sign of a hole
Only thing i can think it is is maybe the float in the carb got stuck for a second or two or a seam on the tank high up has a split. will have to take the tank off and have a looky
Post
by Katgeezer » Mon Aug 26, 2013 5:48 pm
Carbs more likely mate.
When I balanced the carbs I blanked off the vacuum pipe but I still had petrol on the floor from a dodgy float valve. Never does it otherwise so I ignore it!!!
Post
by fossie » Mon Aug 26, 2013 10:35 pm
Yep that's the answer , make like an ostrich , bury your head and forget it until it does it again, otherwise you will be forever chasing answer to a question that may not have one!
Post
by callyboy » Tue Aug 27, 2013 7:33 am
Dont want the bike to dump petrol when i least expect it
Katman
Post
by Katman » Tue Aug 27, 2013 1:08 pm
callyboy wrote:Dont want the bike to dump petrol when i least expect it
& certainly not at the price of the damn stuff
GSX750S3 ANATAK, GSX400SSN, GSX400
MK2 Impulse frame & an almost complete pile of 400 Kat parts to build a hybrid!! GS650G x 1 3/4...........
