1980 650gt sump pan compatability
craven wine
Since I striped the thread on my 83 kat a bottom engine cover has come up on ebay - just checking with the enlightened on here as to whether there's any difference between the two?
Ta
Andy
Ta
Andy
craven wine
Re: 1980 650gt sump pan compatability
partly due to not having a helicoil kit at the moment and the ebay item is reasonably priced... plus advice to the effect that replacement would be preferable..sparki wrote:you stripped the drain plug? why not just repair it?
cheers
Andy
plus you can repair the old one at your leisure and have a spare
i remember fossie mentioning something about the 650 sumps, iirc there are diferent sumps dependant on if you have an oil cooler fitted.
Correct John , model with oil cooler needs to be GS650 GZ or GZ , the GT is different with the oil way blanked off and will pressurise the filter housing causing it to blow off, Don't ask!
craven wine
fossie wrote:Correct John , model with oil cooler needs to be GS650 GZ or GZ , the GT is different with the oil way blanked off and will pressurise the filter housing causing it to blow off, Don't ask!
cheers
Andy
craven wine
yup! wrong sump pan! anyone looking for a pre cooler item - still in wrapping £10 plus postage...
