best carbs for 1170 motor with flowed head
- spondonchris
- Has thanked: 18 times
- Been thanked: 18 times
Thought would ask here first. Got Alex's 1100 motor a few weeks back which looks to have a flowed head. Have very luckily scored an 1170 wiseco kit cheap last week, so question is what carbs are best for this motor set up?
KOC397
- Has thanked: 53 times
- Been thanked: 198 times
Re: best carbs for 1170 motor with flowed head
Road or track use?
For track use you want top end power, so I'd go for 38 mm Mik flatties.
For road use I'd go for 36 mm B12 or Gixxer11 CV carbs.
- spondonchris
Will just be for road use. The old 1170 race motor I have has 33mm smoothbores from when it was raced around 1987, but I assume things have moved on since then, so trying to find out what current thinking is. So reading your two posts it sounds like 36mm is the way forward. I assume using bandit or GSXR carbs will be the cheaper option?
KOC397
Yes, and these will match the stock airbox, too.johnr wrote:efe 36mm cv's are ok too.
...if you're going to have one...
- spondonchris
not planning on running an airbox. Got plenty of time, so will keep an eye out and see what comes up, cheers
KOC397
