Compression
Compression
I've got the paraffin and the zippo ready, but before it gets a Viking funeral I'll give it one more chance. The book says 150 psi. The reading says just under 50psi. This heap has fought me at every stage of the restore'n. Advice on my options will be greatly appreciated.
- Nicky Dodds
- Has thanked: 136 times
- Been thanked: 45 times
Re: Compression
Which bike is this on john?
Re: Compression
50
You sure the tester works John? try it on a known good one first.
If your only getting 50 i would start by sticking a few squirts of oil down the plug and then see what that does.
Re: Compression
if it hasnt run for a Wwhile stuck rings maybe? stick some diesel or wd40 down the bores and leave it a day to do its thing... check again
Re: Compressionaway
It's an S1 that has been stool for a week with a mixture of oil and petrol in the top of the cylinders. Admittingly I've only tested it with a hand held car comp tester, but I thought it would be a bit higher. I'll take it to a bike shop for a professional check but I'm not confident. Do you think I'll get away with a set of rings or look for another engine. I've put too much into it to walk away nor. Cheers John.
- Nicky Dodds
Re: Compression
Should never have sold my S1....loved that bike.
Where the hell are you finding all these projects from?
Well jealous!
Well jealous!
Re: Compressionaway
Is it bollocks an s1 It's the pop-up.............Nurse...is it time for my tablets?jmac wrote:It's an S1 that has been stool for a week with a mixture of oil and petrol in the top of the cylinders. Admittingly I've only tested it with a hand held car comp tester, but I thought it would be a bit higher. I'll take it to a bike shop for a professional check but I'm not confident. Do you think I'll get away with a set of rings or look for another engine. I've put too much into it to walk away nor. Cheers John.
- Nicky Dodds
Re: Compression
You should be my next door neighbour lol
With johnr on the other side and cubeconn over the road
- Has thanked: 638 times
- Been thanked: 243 times
Re: Compression
Nicky Dodds wrote:You should be my next door neighbour lol
With johnr on the other side and cubeconn over the road![]()
