Flasher relay
Posted: Sun Feb 11, 2018 2:08 pm
by Badgerman
Guys just to check, the flasher relay should be three pin to match the block connector on the loom, as all the ones I’ve seen advertised are two pin?
Thanks again
Jamie
Re: Flasher relay
Posted: Sun Feb 11, 2018 4:59 pm
by Kryten
Self Cancelling indicators?
Re: Flasher relay
Posted: Sun Feb 11, 2018 7:40 pm
by Badgerman
The loom is the same as the diagram, so I guess if I order one for an SZ model I should be ok? Just looked on Robinson’s Foundry and they are so expensive, when Wemoto is only £10.....if it’s the right one ;)
J
