Oil pickup debris
Posted: Sat Mar 15, 2025 1:24 pm
by katmarch
I don't think the oil strainer should have these bits in it :? Now I need to work out what they are parts of.
Re: Oil pickup debris
Posted: Sun Mar 16, 2025 8:45 pm
by Kryten
Is that a bit of clutch cover gasket in the 2nd picture bottom right?
Are they metallic? Magnetic?
If not, likely to be cam chain tensioner or clutch plates…
Posted: Sun Mar 16, 2025 10:24 pm
any metalic gold coloured swarf?
Posted: Mon Mar 17, 2025 6:00 pm
by katmarch
The item is rigid plastic, black with a very distinctive curve on the face, also has a straight edge in 1 corner, looks like camchain guide to me but which bit?
Posted: Sun Mar 23, 2025 2:05 pm
by katmarch
Crankcase now dismantled & nothing is missing or broken ;)
Signs of impact under crank on No1
Guessing to 'tinny' noise was the extra bit hitting the oil baffle plate under No 2.
So get a few o rings on the way home tomorrow & get putting it back together, hopefully ready for Odd Balls Rally
Posted: Sun Mar 23, 2025 3:52 pm
by katmarch
Scrap that, part found in pickup now identified as bit of cam chain tensioner where the plunger sits, but mine isn't broken
However main bearing shot
Posted: Sun Mar 23, 2025 7:07 pm
by Kryten
Scrap that, ……..
Ouch! :shock: :shock:
Posted: Mon Mar 24, 2025 9:36 pm
by katmarch
Replacement parts & gaskets on order, tis going to be tight if I can rebuild ready for Odd Balls rally, but I'm going to try to be there.
Posted: Sun Mar 30, 2025 3:13 am
Come on mate we would expect anything less of you :D
