can you bake your brake calipers in the oven.....
Post by callyboy » Mon Jul 11, 2011 4:11 pm
with the seals still inside ? Thinking they get pretty hot when they are on the bike and maybe they would be ok in the oven after they have been painted ?
Feel free to take the piss and ridicule as usual (apart from Johnr, who has reached his monthly target already).
lomsavage
Has thanked: 3 times
Been thanked: 28 times
Re: can you bake your brake calipers in the oven.....
Post by lomsavage » Mon Jul 11, 2011 4:36 pm
yes you can (on lowish, heat)
but word of advise
double wrap in foil with rosemary or some similar pungent herb in outer layer to avoid nasty smells in kitchen
and no i'm not taking the p***
Hello from H
Post by callyboy » Mon Jul 11, 2011 6:25 pm
I heard he had Marjory in the kitchen. May just be a rumour though.
Cheers H. What sort of temp mate ?
Katfish
Been thanked: 29 times
Post by Katfish » Mon Jul 11, 2011 7:04 pm
Yes, if you have just painted them, leave till touch dry then stick them in for about 15 mins at 180, sprinkle with salt and juices from the joint and enjoy!!!!!
Andy...KOC 298
Snap, Crackle & Pop Up
lomsavage
Post by lomsavage » Tue Jul 12, 2011 1:41 am
Blix wrote:I don't believe you have rosemary in your kitchen H ;-)
mick,
i have it growing in the garden actually
H
Hello from H
Post by callyboy » Tue Jul 12, 2011 8:50 am
Back on topic. What sort of temp/time ?
superfly
Post by superfly » Tue Jul 12, 2011 9:42 am
Hi pete,
Why do you want to put them in the oven?
For cooking the paint? if so you can use a hair dryer it will do the job.
Which kind of paint are you using?
Post by callyboy » Tue Jul 12, 2011 10:13 am
Hi Arnaud, Its VHT paint and has to be "cured". You can do it by putting the brakes back on and by using them they would get hot enough to cure. I was thinking it would be better to cure them(harden the paint) before i put them back on(maybe scratch them in doing so).
Dont think a hair dryer would work or if it did, it would take to long.
Hows your bike going ?
Katfish
Post by Katfish » Tue Jul 12, 2011 1:30 pm
Did mine at 180 for 15 mins !!!
Andy...KOC 298
superfly
Post by superfly » Tue Jul 12, 2011 2:54 pm
Hi pete,
You don't have the data sheet of the paint, I think it should be written on it the cured temperation.
I have a mate which paint regulary 2K and he is using a hot air gun to cure it, but a dryer could do to as he told me.
The bike is going well!! Start on the button without choke, and without easy start, however I think the choke not working properly.
I am waiting on the tyres and the exhaust bits should be order tomorow.
I will have a look over this maybe in 1 or 2 weeks when I am off in holiday. :-)
