Hypocrite or coming over to the shiney side. 750 s3
Re: Hypocrite or coming over to the shiney side. 750 s3
We have all been there mate. It will all be worth it when you take your shiney steed out for the first time.
I have found that my 24oz estwing claw hammer to be a great source of stress relief when used to batter to death the cause of my displeasure
- Has thanked: 139 times
- Been thanked: 685 times
Today I will me mostly disassembling it all again. The paint work on the frame is flaking off in places....it is a lovely job but Unfortunatley at the time it was being lacquered in 2 pack the chap was taken ill, and he frame was moved to prevent from getting damaged. However other staff mistook this to mean it was done . So I collected it stored it in a bedroom for a year or so , so only now has the scenario reared it's ugly head.
The plus side is I will get the scruffy bolts zinc plated.
The frame will be re done FOC. Asp.
So last weekends fight with the carbs which took a long while until Smand held he hair dryer in the correct position was a bonding exercise, a dry run if you please, so I will know where the bits go.
However at least I don't live in the south west of England. They have reason to be pis*ed off.
Dont go nicking any of the project bike bolts !!!!!
9lb sledge hammer worked for me, completely destroyed a swingarm gently pressing bearings in!busatoon99 wrote:We have all been there mate. It will all be worth it when you take your shiney steed out for the first time.
Oh the joy of fitting carbs and airbox in, almost forgotten how much fun that was
KOC 49
Carbs go on fairly easy with a ratchet strap, can be a bit fiddly getting airbox rubbers on but there are worse bikes for it.
- Has thanked: 1 time
- Been thanked: 3 times
He's not used to dealing with rubbersPop-Kat wrote:Carbs go on fairly easy with a ratchet strap, can be a bit fiddly getting airbox rubbers on but there are worse bikes for it.
AndySwad wrote:9lb sledge hammer worked for me, completely destroyed a swingarm gently pressing bearings in!busatoon99 wrote:We have all been there mate. It will all be worth it when you take your shiney steed out for the first time.
I agree that a 9lb sledge would provide a more satisfying solution to my source of frustration, but as im a carpenter ive got my estwing hanging off my right hip all day long
So the frame has been redone by jmac in 2 pack .....very nice too.
monday got the bolts , washers etc back from the platers......
NO shiney stuff here no, all plated olive. Cost a bit more but shiney bolts aren't us.
- Has thanked: 79 times
- Been thanked: 70 times
good man!.... got my 650 kat ones done in black
