1000 kat
- Been thanked: 4 times
1000 kat
well its mine and now it starts lol got to find out if it's a rare one or do I restomod it ? decisions decisions I'm going to need a set of pipes as they are bodged
Re: 1000 kat
so now what yo do I've got a set of the standard wheels and a set of smooth bore carbs as well in a box
- Has thanked: 139 times
- Been thanked: 685 times
Re: 1000 kat
The answer is it probably a replica of the sxz, as it comes with the standard stuff, but hey That doesn't matter ,what you have is the 1980's ultimate restomod. So No don't add modern bits just clean it and ride it. It is worth more as it is now for a start than it would after adding modern running gear.
- Has thanked: 266 times
- Been thanked: 365 times
Re: 1000 kat
as i said in the other thread, ride it, get it on the road and put some miles on it, only then will you know if its what you want and if so, what you could do to make it better for you. that might be a rebuild to stock or it might be a rebuild with modern running gear etc, but dont start spending cash till you know for certain where you want to end up.
- Has thanked: 25 times
- Been thanked: 12 times
Re: 1000 kat
Do you still have a set of smoothbores?johnisleofman wrote: ↑Sun Oct 20, 2019 1:47 pm20191020_101317.jpg so now what yo do I've got a set of the standard wheels and a set of smooth bore carbs as well in a box
