Charity Bike Build - 1100SZ
- Has thanked: 7 times
- Been thanked: 47 times
Re: Charity Bike Build - 1100SZ
I managed to find the three remaining missing lines. Brand new in Austrailia, sadly cost a fortune. I need the rubber bits that the lines run through next to the mudguard.
- Has thanked: 33 times
- Been thanked: 63 times
The rubber bushing, part number 59244-49000, is showing as available from CMSnl for 4 Euros each.
https://www.cmsnl.com/products/bush-bra ... 9NpTazgqzI
If they are not actually available from there, then a very similar part is fitted to old leaf sprung Land Rovers, Rover part number 06860. I have measured both and the Land Rover part is only a few mm longer than the Suzuki part, and the i.d. is about the same.
https://www.ebay.co.uk/itm/LandRover-Se ... 2443419066
I went to Venhill this morning. They only make stainless steel braided hoses. It is available in black. The outside diameter is 6.5mm. Their web site is showing a kit for the 1100 E/S Katana, at £129.72 inc VAT.
https://www.venhill.co.uk/partfinder/se ... 7&year=133
Hope this helps
David
Hope this helps
David
- Has thanked: 639 times
- Been thanked: 232 times
That is handy info thanks!GSF34058 wrote: ↑Fri Dec 11, 2020 1:04 pmIf they are not actually available from there, then a very similar part is fitted to old leaf sprung Land Rovers, Rover part number 06860. I have measured both and the Land Rover part is only a few mm longer than the Suzuki part, and the i.d. is about the same.
- Has thanked: 34 times
- Been thanked: 114 times
I have 1 x 59244-49000. I will order another and post to you. Pm me your address.
Suzuki have discontinued 59244-49000. I can send you the one I have, let me know where to post to.
This is what I gave the part number for, and what I thought you wanted.
https://www.ebay.com/itm/NOS-Suzuki-Bra ... 4227943551
and here
https://www.ebay.co.uk/p/22024574787
Or did you mean something else?
David
Ok, perfect, we need a pair of them, thanks so much for the kind offer
