Sam made those brackets for me i think.... was soo long ago now. brackets were sold some time ago... it used the pinchbolt at the bottom and there was a threaded bit of bar at the top to monut the satnav mount to... the orientation was multi-directional so twist it to wherever you wanted it... was for a phone at the time. sam is pretty good, just give him so basic dimentions and an idea of what u want, and he cobbles up a pic of it for your approval etcJonty wrote: ↑Sat Mar 18, 2023 8:08 pmCheers, that's where I was thinking of mounting, its a big screen but landscape.Uncle Bob wrote: ↑Sat Mar 18, 2023 4:38 pmSparki had a neat one off the top of the steering stem pinch bolt. Haven't got a decent photo of it, here's 3 I have. He sold the bike, he might have kept the bracket - you could ask him. It's going to cover the speedo somewhat
I still prefer maps - they don't crash! but I have found with age I can't read them while riding along anymore
I just use my phone when i want a GPS in the tank bag top (or map pocket on tank).
So used to sat nav paradigm from the car!
Will see if he's got any pictures, is that his name in the forum?
Sat nav fitting
- Has thanked: 79 times
- Been thanked: 70 times
Re: Sat nav fitting
Re: Sat nav fitting
theyre my old ones i thinkKryten wrote: ↑Sun Mar 19, 2023 3:43 pmSat Nag mounting bar is 25mm diameter x 40mm long. Drilled and tapped each end for 6mm
Brackets are 6mm thick.
Holes at 65mm centres
M6 clearance at top. Radius of top bit is 12.5 mm.
M8 clearance at bottom of bracket. Radius of bottom bit is 9mm.
The offset is achieved by machining a couple of curves in the ally sheet that give you some clearance over the top yoke see photo.
- Has thanked: 25 times
- Been thanked: 12 times
Re: Sat nav fitting
yes, Sam made them, he asked if still had the original drawings as he wanted dimensions.sparki wrote: ↑Tue Mar 28, 2023 3:46 pmyes, Sam made them, he asked if still had the original drawings as he wanted dimensions.Jonty wrote: ↑Sat Mar 18, 2023 8:08 pmCheers, that's where I was thinking of mounting, its a big screen but landscape.Uncle Bob wrote: ↑Sat Mar 18, 2023 4:38 pmSparki had a neat one off the top of the steering stem pinch bolt. Haven't got a decent photo of it, here's 3 I have. He sold the bike, he might have kept the bracket - you could ask him. It's going to cover the speedo somewhat
If you dont mind me asking, how much were they?
Re: Sat nav fitting
it was so long ago i honestly dont recal... they were nice and made to how wanted them so didnt mind. i dont recal them being ott
- Has thanked: 95 times
- Been thanked: 239 times
Re: Sat nav fitting
Ok in addition to the info posted above........
I have scanned the side plate and also done a crude reverse engineering for you.
And yes it is the one owned by Sparki, I bought it couple of years ago off him and no I can't remember how much I paid either.
Used on the trip down to The Mayflower Wussie Kat with good results (apart from the electrical fry up).
I think the hieroglyphics are readable
Just looked at that and realised that the spec for the bolt is wrong! Should be M8 X 65
Re: Sat nav fitting
Here's a .pdf that if you print out on A4 paper should be 1:1
Sorry not able answer phone at moment as I have family stuff going on that kinda takes precedent over the other stuff. Should be back to normal by end of week. Just in time for Easter holidays, grand kids visiting and a trip to Cider Country for a wedding!
- Has thanked: 266 times
- Been thanked: 365 times
Re: Sat nav fitting
i bought a cheap (30 quid) satnav off ebay it locks to its base with a grubscrew and cant be used if you dont have the mounting. as a cheap chinese satnav its unbranded and totally un nickable. ive been using the same make for years on different bikes. that way its secure cos it isnt worth robbing, and if it does get robbed, its useless cos the base is bolted to the bike.
- Has thanked: 34 times
- Been thanked: 114 times
Re: Sat nav fitting
Hi John, could you give me the make/model?
I was going to get a Beeline satnav, but maybe this cheapie will be a better solution.
Re: Sat nav fitting
the ones i use are called fodsport, theyre just a generic android based satnav. got one on the beemer as well as the one for the kat. theyre pretty cheap, i bought both these new and didnt pay over 30 quid for either. theyre on ebay for upro 120 quid, but there are realistically priced ones out there if you look. mine have both got european mapping on them.
