front wheel spindle
front wheel spindle
Messing about with my "cough" Impulse and was looking at fitting some wheels that John sold me ages ago. The spindle from my Impulse seems to rattle around a bit inside the front new wheel. I think the spindle is 15mm. Anyone know what else might fit thats a bit bigger ? John tells me it a mk2 Impulse wheel, but is kinda generic throughout that time.
Think I need a 17mm
Think I need a 17mm
Re: front wheel spindle
can swap the wheel bearings over..............or find some which will work !
bobster wrote:can swap the wheel bearings over..............or find some which will work !
Thanks for that Rob. Be easier to get a bigger spindle I thought.
- Katgeezer
- Has thanked: 6 times
- Been thanked: 8 times
Spindle still has to go thro' the fork bottoms tho Pete.
More work swapping bearings but a better result.
Obviously you need to do a bit of accurate diameter checking but it's the better way in this instance IMO.
Been looking at a front spindle diameter chart and most Suzuki's seem to have 15" spindles on the front. John told me these wheels were of a MK2 Impulse which seem to be the exception to the rule
Cheers for the offer mate. Will go and stare at it for a bit tomoz first. Then make up my mind.
http://www.dotheton.com/forum/index.php?topic=20952.0" onclick="window.open(this.href);return false;
- Been thanked: 716 times
Different set up on mk2 impulse to mk1 . The mk2 is like the 400 kat and 17mm at one end and threaded into fork at the other.
Hence why a lot of 400 Kats end up with 3 spoke wheels ala Impulse (Mk2), which is my plans with my hybridfossie wrote:Different set up on mk2 impulse to mk1 . The mk2 is like the 400 kat and 17mm at one end and threaded into fork at the other.
KOCUK 046 Jez
to be continued
to be continued
Anyone know a good place for bearings. My local bike shop couldnt find the right size to fit. I need to measure the outside diameter i spose.
