front sprokets
dave309
front sprokets
Post by dave309 » Thu Mar 24, 2011 11:48 pm
hi all im after a front 530 sprocket with a 3/8 offset for my 1100 any idears best place to start looking thanks
Katgeezer
Has thanked: 6 times
Been thanked: 8 times
Re: front sprokets
Post by Katgeezer » Fri Mar 25, 2011 10:38 am
As a starting point there's Ray Debben, £45.
Re: front sprokets
Post by johnr » Fri Mar 25, 2011 11:52 am
i ground all the teeth off an old sprocket and welded it onto a new sprocket as a spacer. if you only need 3/8ths you might find that the sprocket will still be on the splines of the shaft with just an extra spacer behiond it. i only made mine up to increase the contact area between sprocket and splines to reduce wear on both.
Has thanked: 80 times
Been thanked: 72 times
Re: front sprokets
Post by sparki » Sat Mar 26, 2011 6:24 pm
get a std sprocket and get a spacer machined up for behind it... there's enough thread left for the tab washer too. that way if you need to change again in the future all ya need is the sprocket...
KOCUK - 241
Poochy
Re: front sprokets
Post by Poochy » Thu Mar 31, 2011 1:26 pm
To get the correct chain alignment and the correct wheel alignment for something like a17 x 4.5" wheel with a 160 tyre you need to use a 3/8" offset sprocket with a spacer behind it bring the inner part of the sprocket out to the edge of the output shaft splines.
There's a company based near Silverstone called Trident Engineering that supply them for reasonable money.
http://www.silverstonesuperbikes.co.uk/ ... ts_14.html
Re: front sprokets
Post by sparki » Fri Apr 01, 2011 12:44 pm
cheaper than getting a fat washer made and a std sprocket?
KOCUK - 241
