new suzuki base gasket arrived earlier.... one side is smooth... the other side has a little bead of some silicone sealing type stuff on the sticky out bits in front of, and to the rear of, the camchain tunnel... i'd put it on with the beaded side face down (as in against the crankcase)... but wonder if anyone knows better or if the orientation matters at all?
thanks all...
650 base gasket question
- Has thanked: 120 times
- Been thanked: 257 times
Re: 650 base gasket question
So what was the answer, for the benefit of non-bookfacers?
- sparki
- Committee Member
- Has thanked: 80 times
- Been thanked: 72 times
