Katana 1000 U.k import Carb issue
Re: Katana 1000 U.k import Carb issue
Post by bobster » Wed May 21, 2014 8:33 pm
They never had 34mm Smooth bore carbs they had VM32 round slide carbs in the UK!
I will try and find the info you need for the VM32 slide carbs...........Give me a day or 2 to dig out the manual....
I do know they had 95# main jets!
There was never a fuel metering screw figure as these were set at the factory by a fancy machine.....2 - 2 and a 1/2 turns out would be a good starting point though!
As for the pilot air screw 1 and 3/4 turns out springs to mind! Just play with them til it runs ok!
Post by bobster » Thu May 22, 2014 11:37 pm
Dont think they are the same on the 1100 carbs.......search for GS1000 needle valve on ebay USA, as there are quite a few on there but quite expensive, although there are some used ones, but id be a bit wary of using used ones.
Take a look at this ebay item number 301048084572 for used ones
Or Take a look at this ebay item number 181215785547 for new ones, but theyre expensive
Been thanked: 198 times
Post by Pedda » Fri May 23, 2014 2:22 pm
When I read your user name, this is what hit my memory...:
:shock:
Got anything to do with that awsome beast?
